Misfire
250,000 MILES • 4.3L • 6 CYL
LORENZOMCG 57
Bad misfire and check engine light will flash when the speed is above 50 MPH.
Jan 28, 2021 at 4:40 AM
Good afternoon,
How old are the ignition parts such as plugs, wires, cap, and rotor? That would be a good place to start.
I would check the compression to be sure there is no internal engine damage.
I would also check the fuel pressure to be sure there is sufficient fuel being delivered to the rail.
May 5, 2021 at 6:43 AM
