Misfire/backfire
175,000 MILES • 7.4L • V8 • 4WD • AUTOMATIC
BRIAN WEBSTER
Hey guys, I have the vehicle listed above it has a big block in it. Had a backfire, changed out the plugs and fuel filter. Sprayed a couple squirts of carburetor cleaner in the throttle body. Now she idles something awful! And still backfires. I cleaned the K&N air filter and I did not check with a gauge but I did push down on the Schrader valve and heard the push of air and plenty of fuel came out. Fuel filter had quite a bit of pressure as well. Thoughts?
Dec 19, 2017 at 5:18 AM
  • 55,732 POSTS
Yes this sounds like you may have a flat camshaft or low compression which would indicate a burnt exhaust valve. Here are guides that will help us get started to find out what the problem is.
and
https://www.2carpros.com/articles/engine-backfires-while-running
and
Let us know what happens and please upload pictures or videos of the problem.
Cheers, Ken
Dec 20, 2017 at 6:32 AM
