Misfire at low RPMs?
117,500 MILES
HABIB2022
  • 10 POSTS
Engine misfires at low RPMs.
Oct 29, 2023 at 6:59 AM
  • 110,248 POSTS
The first thing to do is have the computer scanned for diagnostic trouble codes. This way, we will know if it is one or more cylinders and which ones are causing the misfire.
Here is a link that explains how to scan for codes:
Next, when was the vehicle's last tune-up? Has anything been done recently that may have caused this to happen? Does the check engine light stay on solid or flash while driving?
Let me know as much as you can. I mentioned scanning the computer. If you don't have a scan tool, most parts stores will scan it for you free of charge. Have it done and let me know what codes are stored.
Additionally, take a look through this link and let me know if it helps:
Oct 29, 2023 at 12:45 PM
HABIB2022
  • 10 POSTS
Scanned the car. It gave me codes with random misfire P0300 and misfire cylinder 1 P0301 and misfire cylinder 4 P0304.
Changed the spark plugs but it still misfires at low RPMs.
Oct 29, 2023 at 1:25 PM
  • 110,248 POSTS
Next, check to see if there are any engine vacuum leaks. That can cause issues.
Here is a link that explains how it's done:
Also, if you have a live data scan tool, let me know what the short-term fuel trims are with the engine at operating temperature.
Take a look through this link as well, you may find it helpful:
https://www.2carpros.com/articles/automotive-engine-misfire-code-p0300-causes-and-solutions
Oct 29, 2023 at 2:05 PM
HABIB2022
  • 10 POSTS
Short term fuel trim bank 1 is 0.8 %
Short term fuel bank 1 sensor 2 is 99.2 %
Oct 29, 2023 at 9:16 PM
  • 110,248 POSTS
If sensor 2 is at 99.2%, either we have low fuel pressure, a rather large vacuum leak, or the sensor is faulty.
Since you have a live data scan tool, watch the voltage signals from B1S2. It should adjust itself between 0.1 and 1.0V. If you notice no change in the voltage, replace the sensor. It is the likely issue. However, also confirm there isn't a wiring or connector issue.
Let me know what I can do to help.
See pics below. Note: B1S2 is after the catalytic converter. I attached pics showing both sensors. The air/fuel sensor is sensor 1 (pic 1). The heated O2 sensor is in pic 2 below.
Oct 30, 2023 at 11:20 AM
HABIB2022
  • 10 POSTS
Hello!
I don't think the B1S2 is faulty, the reading is normal. I will send you a video recorded from the live data.
Oct 31, 2023 at 5:53 AM
HABIB2022
  • 10 POSTS
Take a look.
Oct 31, 2023 at 6:02 AM
HABIB2022
  • 10 POSTS
Take a look!
Oct 31, 2023 at 6:06 AM
HABIB2022
  • 10 POSTS
Here are some screenshots.
Oct 31, 2023 at 6:09 AM
  • 110,248 POSTS
I watched the video. The STFT shows 99.2%. That usually indicates the fuel trim isn't being used. Was the engine at operating temperature?
The voltages are within spec for sensor 2. Sensor 1 is higher than expected, but if the vehicle was cold, that could be a reflection of a rich air/fuel mixture.
Oct 31, 2023 at 12:04 PM
HABIB2022
  • 10 POSTS
The engine was at the operating temperature.
Oct 31, 2023 at 7:00 PM
HABIB2022
  • 10 POSTS
What do you think about the reading voltage of O2 sensor B1S1?
It's always above 3 volt!!!!!
Oct 31, 2023 at 9:50 PM
HABIB2022
  • 10 POSTS
What's the voltage range reading of O2 sensor B1S1 in Toyota Corolla 2013?
Oct 31, 2023 at 10:39 PM
  • 110,248 POSTS
Normally, the voltages should range between 0.1 and 1.0v. However, although 3v is high, it isn't uncommon. Especially if the engine is cold. That's why I asked.
As far as testing is concerned, the manufacturer doesn't provide a voltage reference point. Instead, they want you to check the resistance in the sensor itself.
I attached those directions below.
See pics below. I never confirmed if this is a 1.8L or a 2.0L. Also, the information provided below is bank 1 sensor 1. Your crazy readings are for sensor 2. Confirm the engine size for me.
Nov 1, 2023 at 11:19 AM
