Misfire at idle
134,750 MILES • 3.0L • V6 • 2WD • AUTOMATIC
TOYOTYING
Engine misfires at idle, cold or hot, cannot identify a particular cylinder. I have replaced plugs and wires, does not lose coolant or bubble in radiator. does not use oil, no unusual noise. seems smooth at higher rpm. maybe down a bit at power. also replaced distributor cap.
Mar 24, 2018 at 3:34 AM
Good afternoon.
I would start by performing a compression test on all the cylinders to be sure there is not an internal issue.
If you do not have a tester, you can rent one at a parts store.
Mar 24, 2018 at 6:15 AM
