Misfire and clutch
  • 109,885 POSTS
You know, when you depress it, you place lateral pressure on the crank. I wonder if there is excessive end play in the crank? Worn thrust bearing on the crank aren't uncommon with a manual transmission.
Just a thought.
Sunday, November 3rd, 2019 AT 8:59 PM
NASER NASER
  • 836 POSTS
Not sure, 72,000 on the car, harmonic balancer doesn't wobble or play.
Monday, November 4th, 2019 AT 3:37 AM
  • 109,885 POSTS
Okay. If there was excessive end play, then it would make sense. Since it has low mileage, there is even a lower chance of that as a problem unless it wasn't serviced properly.
Monday, November 4th, 2019 AT 8:17 PM
