misfire after warm up
109,112 MILES • 3.4L • V6 • 2WD • AUTOMATIC
WLBROOME
misfire after warm up. runs great when cold. has new engine new plugs wires injectors when starts misfiring can shut down start back up and runs fine until a few minutes then starts again.
Apr 10, 2017 at 4:34 AM
  • 55,743 POSTS
This sounds like you have an intake valve that is leaking. Can you do a leak down test to confirm the issue?
This guide can help as well.
Cheers, Ken
Apr 10, 2017 at 5:10 AM
WLBROOME
No vacuum leaks. while driving you can shut off and restart and misfire goes away for a mile or so then comes back. like I said runs great when cold. but fifteen to twenty minutes driving starts misfiring.
Apr 10, 2017 at 5:48 AM
HMAC300
  • 48,601 POSTS
This sounds like you have a stuck lifter holding the valve open. I would remove the valve cover and check the valve lash.
Apr 10, 2017 at 8:04 AM
WLBROOME
Fuel pressure is good. New crank sensor. 3x sensor replaced. Was told to disconnect 24x sensor and see if problem was still there. Was told if it did not misfire with disconnected to replace sensor. Still misfires. Have replaced PCM as well. So I did what you said and the intake lift cylinder #3 is tight. So I took the afternoon and replaced all lifters and the engine has never run better. Thanks for the help I love this site.
Apr 10, 2017 at 8:30 AM
  • 55,743 POSTS
Glad you could get it fixed, that kind of problem can be tough. Please use 2CarPros anytime we are here to help.
Cheers, Ken
Apr 11, 2017 at 2:45 AM
BLEDION KORDALLI
I have the same problem like WLBROOME..please help what can I do..
Mar 23, 2019 at 12:18 AM
BLEDION KORDALLI
I have replace crank sensor..
Mar 23, 2019 at 12:30 AM
BLEDION KORDALLI
Can camshaft sensor do this problem?
Mar 23, 2019 at 12:31 AM
  • 55,743 POSTS
Not really can I ask if when you installed the new spark plugs if you used:
Spark Plug Type .................... AC R43TSK if not start here it must have these spark plugs. Here is a guided to help you install them correctly:
https://www.2carpros.com/articles/how-to-change-spark-plugs
Mar 23, 2019 at 7:37 AM
