Misfire
130,000 MILES • 1.8L • 4 CYL • 2WD • AUTOMATIC
GLEN DIXON
Compression test 1' 110 psi. 2' 110 psi 3' 110 psi 4' 120 psi. Cold test.
Oct 10, 2017 at 6:36 PM
  • 31,937 POSTS
Compression's are okay, look for a bad plug or lead. check for tracking around the coil this is a pencil like carbon smear or line which would indicate a voltage leak to ground. faulty injector or a vacuum leak. also, a code read will be of help, start here.
Oct 10, 2017 at 7:52 PM
RENEE L
  • 1,260 POSTS
Hi GLEN DIXON.
If you decide you would like to conduct the scan yourself here is a link to an article that features written step by step instructions and pictures explaining how to do the scan yourself. Also, I have included a link to our YouTube channel with a how to video on code scanning.
This is applicable even if your check engine light is not on.
Most scanners are inexpensive to purchase, you can purchase one online from sites like Amazon.com
https://youtu.be/YV3TRZwer8k
Once you have the codes please get back to us so that we can further assist you. We are always happy to help.
Thank you for visiting 2CarPros.com.
Kindest regards,
Renee
Admin
Oct 11, 2017 at 4:20 AM
