Misfire
180,000 MILES • 1.5L • 4 CYL • 2WD • MANUAL
HOOGSTAD
Change spark plugs, lead coil and compression check. All fine. Changed injectors, change crank angle sensor, change ECU. Still misfire on three and four.
Dec 12, 2017 at 3:16 PM
  • 31,937 POSTS
May be a blown head gasket starting between 3 and 4 do a leak down test and also check for a leaking inlet manifold gasket at 3 and 4 spray a little brake clean around the manifold while running to see if the revs lift, if so you will have a leak.
Dec 13, 2017 at 8:19 PM
