now I have multiple misfires?
150,000 MILES • 5.0L • V8 • 4WD • AUTOMATIC
TRUEBA
It was running perfectly fine but I wanted to change spark plugs well I did the drivers side first then I had to run down the street it ran perfect then I changed the passenger side and now I have multiple misfires
Apr 17, 2026 at 2:32 PM
  • 55,711 POSTS
Yes, this can happen when one or more of the spark plugs have been cracked while installing them, did you use a spark plug socket? Spark plugs are fragile so they can be damaged while being installed. I would remove the spark plug and inspect them. Also, I would change out the spark plug wires and possibly the ignition coil pack. Please let me know what you find.
Apr 18, 2026 at 2:21 AM
