Misfire
2004 KIA SEDONA
247,465 MILES • 3.5L • V6 • FWD • AUTOMATIC
CARAHOLIC
Cylinder #6 misfire changed plugs wires boots coil still misfire drive it one time doesn't mix then drive it back home it starts missing its an intermittent problem
Mar 10, 2016 at 10:41 AM
HMAC300
  • 48,601 POSTS
Check the fuel pressure with a gauge. Most auto parts store rent them. Check for a vacuum leak an EGR stuck open or clogged passageways, finally have a freeze frame done on it.
Mar 11, 2016 at 12:08 AM
MAXIMILIAM
  • 436 POSTS
Could it be the injector?
CARAHOLIC
Mar 11, 2016 at 8:41 AM
HMAC300
  • 48,601 POSTS
Yes but until you check the other things you could change it and still have the misfire. or low compression on that cylinder among other things.
Mar 11, 2016 at 8:45 AM
