Login
Join
Ask a Question
Questions by Vehicle
Repair Topics
Testing / Diagnostics
Repair & Service Guides
Symptoms
Warning Lights
Trouble Codes
How It Works
Videos
Login
Become a Member
Home
Mercury
Marquis
Engine
Symptoms
Misfire
misfire after replacing plenum gasket
1992 MERCURY MARQUIS
160 MILES • 4.6L • V8 • 2WD • AUTOMATIC
WESTRUCK
MEMBER
Changed intake plenum gasket engine began to misfire after start up.
Sep 27, 2019 at 1:00 PM
Experienced Mechanic
Welcome to 2CarPros.
Check to see if there are any vacuum leaks. Chances are something came disconnected or broken. Here is a link that will explain how to check:
If nothing is found, retrieve diagnostic trouble codes. On this vehicle, all you need is a test light. Follow the directions in this link.
https://www.2carpros.com/articles/ford-lincoln-mercury-obd1-1995-and-earlier-diagnostic-trouble-code-definition-and-retrieval
Let me know what you find.
Sep 27, 2019 at 1:43 PM
Add image or video
Ask a new question
Engine won't start
Engine stalls while driving
