Misfire one coil park and same one injector misfire
2002 NISSAN ALMERA
16 MILES • 1.6L • 6 CYL • 2WD • MANUAL
ELPHAS MONGEZI ELPHAS
When the engine running I tried to remove a cable from injector but it doesn't show it function. also, the same to coil park when I remove it does the same. I swapped them, showed that are not damaged. I even bought new of them but still problem not solved. but shows the fire is sparking there.I checked there air sensor, air flow sensor, fuses, petrol pump relays. I also skimmed the top engine, replaced the guscate and valves.can you please help? I already spent a lot of money on it.
Jan 16, 2021 at 4:00 PM
Good morning,
I would start by checking the compression to be sure there is nothing wrong with the engine internally.
Can you give me the code numbers that were set?
You have covered all the basics but now you need to go to the next step and check the compression.
Jan 16, 2021 at 10:17 PM
