Why are cylinders two and six misfiring under load?
121,000 MILES • 3.2L • 6 CYL • 4WD • AUTOMATIC
SAMUELHDZ98
Misfire only cylinder 2 and 6 when you go above 4,000 RPMs and under load.
Jul 24, 2022 at 11:05 AM
BORIS K
  • 836 POSTS
Are you using a diagnostic tool to check the misfire counters?
Have you tried replacing spark plugs and swapping ignition coils from okay cylinders, say 1+4, and then see if the misfire moves to the other cylinders?
See cylinder layout at bottom.
Also look at below link.
Cheers, Boris
Jul 25, 2022 at 12:23 AM
