No one should ever assume, and yes I totally agree with you. These engines are well designed and should last well over 200,000 when properly maintained.
With that in mind, the first thing I would do is check for diagnostic trouble codes. Here is a quick video showing how that is done:
https://youtu.be/YV3TRZwer8k
Now I realize most people don't own a scanner, but most parts stores will do it for free. Once that is done, we will know which cylinder is missing. The diagnostic trouble code that is retrieved will indicate that.
With that information, I would simply remove the spark plug and inspect it. If it is good, I would then switch the coil pack from that cylinder with a cylinder that isn't missing. Next, clear the codes and drive the car. If the check engine light comes back on, see if the misfire moved to a different cylinder. If it did, the coil pack is bad and needs replaced. If it didn't, then I would check engine compression to determine if any of the cylinders are low.
Here are a few links that you may find helpful. Take a look through them. They discuss engine misfires, how to diagnose them, and how to repair. Additionally, I am attaching the procedures for replacing spark plugs.
https://www.2carpros.com/articles/how-to-change-spark-plugs
Now, check to see what the diagnostic trouble codes are. Keep in mind, those codes you get when scanning the computer can be extremely helpful. Let me know what they are.
Jan 26, 2019 at 3:04 PM
