Misfire - replaced the coils, spark plugs, fuel injectors?
300,000 MILES • 2.4L • AUTOMATIC
JOE1953
  • 814 POSTS
Cylinder #1,195psi
Cylinder #2,190psi
Cylinder #3, 185psi
CylinderCylinder #4,190psi
I done replaced the coils, spark plugs, fuel injectors and camshaft position sensor and still have a misfire on #3 and #4 cylinder can you tell me what is causing the misfire please?
Jul 30, 2026 at 11:55 PM
  • 55,844 POSTS
Yep, you have a blown head gasket between cylinders. I would remove the cylinder head and replace the gasket. You have done everything else.
Jul 31, 2026 at 7:22 PM
JOE1953
  • 814 POSTS
the exhaust manifold is glowing red hot what is causing that? and how do i check for a blown head gasket between cylinders?
Jul 31, 2026 at 11:31 PM
  • 55,844 POSTS
Why don't you continue with the thread you started for this problem and we keep starting over?
Aug 1, 2026 at 9:54 AM
JOE1953
  • 814 POSTS
the radiator is not loosing any coolant the oil dipstick, oil cap is not milky looking.I took the valve cover off and check the timing chain for slack between the camshaft sprockets there is about 3/8-inches of slack.
Aug 11, 2026 at 10:38 PM
  • 55,844 POSTS
Here is a guide to go over.
https://2carpros.com/articles/engine-misfires-or-runs-rough/
Aug 13, 2026 at 7:15 AM
JOE1953
  • 814 POSTS
i don't see no valve spring on this engine so explain the 3/8-inches slack between camshaft sprockets will this cause misfire and rough idling on #3 and #4 cylinder?
Aug 13, 2026 at 10:23 AM
  • 55,844 POSTS
Did you go over the guide and test everything it said too?
Aug 14, 2026 at 7:47 AM
JOE1953
  • 814 POSTS
yes i went over evereything i need a video on how to replace the complete timing chain set.
Oct 24, 2026 at 5:53 PM
  • 55,844 POSTS
JOE1953
  • 814 POSTS
i replace the timing chain the statioary chain guide and the tensioner pivot arm/chain guide do slack support to be between the camshaft sprockets? after i replace the timing cover i can't get the timing chain tensioner to go all the way in to bolt it down. i was thinking the slack suppose to be on the tensioner pivot arm/chain guide side.
Oct 26, 2026 at 6:23 AM
  • 55,844 POSTS
A new tensioner has a release pin/clip you need to remove after installation.
Oct 26, 2026 at 9:03 AM
JOE1953
  • 814 POSTS
what is a release pin/clip? i see like a hook do it release after i install the tensioner and rotate the engine? will you explain your answer a little more?
Oct 26, 2026 at 10:49 AM
  • 55,844 POSTS
Yes, the tensioner has a release pin or clip that needs to be removed after installation. Can you upload an image of the tensioner so I can show you?
Oct 27, 2026 at 8:04 AM
JOE1953
  • 814 POSTS
i don't know how to upload a image, but i am talking about the timing chain tensioner where it go through the timing cover to the tensioner arm i think it keep the slack out of the chain. do oil pressure work this tensioner too? after i install it do i rotate the engine two revolution to make sure the marks lineup on the crankshaft sprocket and the camshaft sprockets? i want to make sure it is in time. will you explain the oil pump chain and sprocket and how to line the mark on it? but what i did i rotate the engine to number one piston at top dead center and replace the timing chain on the camshaft sprockets with the two color link close together lineup with the marks on the cam sprockets and bearing cap and color link further away lineup with the mark on the crankshaft sprocket did i do this the correct way?
Nov 27, 2026 at 12:36 AM
JOE1953
  • 814 POSTS
I done replace complete timing chain kit, spark plugs, ignition coils, fuel injectors and oil pump and the engine still have a misfire on #3 and #4 cylinder and the codes are PO303 and PO304 engine light is still flashing what it take to fix this problem please help?
Nov 27, 2026 at 12:45 AM
