Misfire in cylinder one po301 code
8 MILES • 4.6L • V8 • 2WD • AUTOMATIC
MRFANTASTIC49
I started getting code po301 and sometimes code po303 cylinder misfire. I changed the spark plugs wires and ignition coil and last rotated the fuel injectors. still I cannot get rid of the misfire in cylinder one po301 code. I am stumped. any ideas please?
Nov 27, 2017 at 12:25 AM
  • 31,937 POSTS
Check compression's just to make sure that there is not a problem there. also, check for a vacuum leak around the manifold and check fuel pressure and if all these are okay, get the injectors flow tested, start here.
Nov 27, 2017 at 1:17 PM
