Misfire and codes po113, po128, po351, po356, and p1299?
341,000 MILES • 4.6L • V8 • 2WD • AUTOMATIC
ANAHN
E150 had slight misfire and no codes. replaced 6 plugs and 1 coil' plus thermostat and O-ring gasket. The O-ring was not aligned right it sprayed engine with coolant temperature went up pulled over let cool and refilled radiator and overflow. replaced O-ring gasket, now it has codes, misfire is worse. I didn't reset codes after O-ring issue. Codes: po113, po128, po351, po356, and p1299. says no DTC detection found, see manual.
For only the last code: p1299
Help!
Jul 13, 2023 at 10:59 PM
AL514
  • 5,700 POSTS
Hello, it sounds like some of the coolant that sprayed around the engine may have gotten into a bulk connector or down into some of the spark plug holes or into some of the ignition coil harness plugs, I know this vehicle has coil over plug design, but these codes, P0351 and P0356 are ignition coil circuit primary/secondary codes. So, I would inspect each coils harness plug and the spark plug hole for any possible coolant intrusion. As for the P0113 Intake Air Temperature (IAT) sensor circuit high Bank 1, this is another circuit code, the IAT is part of the Mass Air Flow sensor on this vehicle. I'm not sure how much of the engine was sprayed with hot coolant, it sounds like quite a bit. The PCM is located on the passenger side rear of the engine compartment, so I think going through and checking the wiring harness throughout the engine compartment as well as the PCM connectors is a good idea, The other codes I think are just because of the loss of coolant. P0128 Coolant Temperature Below thermostat regulating temperature, and P1299 is Cylinder Head over Temperature protection.
The coils that set codes are A and F, I will try to find some service info on those locations, I assume A is cylinder 1. But I'll check
You can clear the codes now, I have them all written down.
This does have a coil per cylinder, correct? I'm not finding any E Series Van, but the F150 looks to be the same exact setup,
Also, what brand spark plugs did you recently install?
This is the OEM Ford Motorcraft spark plugs that should be installed. I highly recommend using the OEM on any Ford. especially with the amount of cheap aftermarket parts that are out, going bad constantly. Sometimes right out of the box.
Jul 14, 2023 at 7:45 AM
