when engine is warm there is blue smoke coming from the dual exhaust, also misfire code reading on cylinder number five
153,000 MILES • 5.7L • V8 • 4WD • AUTOMATIC
LISA SIEGMAN
  • 21 POSTS
I have blue smoke coming out of my dual exhaust only when it is warm and I am getting a misfire reading on cylinder number five. oil is good and so is the pressure, oil cap is good and antifreeze level is good. I did a compression test and it passed. what could this be it is driving me insane?
Dec 16, 2016 at 7:29 AM
HMAC300
  • 48,601 POSTS
misfires are a tough to find even for a mechanic. he has to check sensors with his scanner and injectors. if compression is okay it can be a bad wire/spark plug really anything these are best handled by a professional for your cheapest option.
Dec 16, 2016 at 7:35 AM
LISA SIEGMAN
  • 21 POSTS
Plugs are brand new and so is coil pack, plugs and wires. it is just on number five.
Dec 16, 2016 at 7:40 AM
JOHNNY G.JR
  • 320 POSTS
blue smoke, check your PCV valve and engine breathing system.
Dec 16, 2016 at 7:47 AM
STEVE W.
  • 15,413 POSTS
I take it all this was done for the misfire and smoke?
Blue smoke, misfire on 5 in a 5.7, could be a split intake valve stem seal or a collapsed oil control ring. Pull the plug out and see what it looks like. Borrow/rent an inspection camera and take a look inside the cylinder for carbon on the head/piston. Compare it to a couple other cylinders. If it is clean then it probably is not the seal. If it is oily/sooted up then you are getting oil. Compression test would not show either one. Both require visual inspection.
Dec 16, 2016 at 8:26 AM
HMAC300
  • 48,601 POSTS
normally on this engine the seals for valve stems wear out at the mileage and age that would clear up smoke if all intakes were replaced but misfire is something else. unless guides were worn out.
Dec 16, 2016 at 9:05 AM
LISA SIEGMAN
  • 21 POSTS
It ran fine until I had a fine tune done and after I had it done it started doing this.
Dec 16, 2016 at 10:06 AM
STEVE W.
  • 15,413 POSTS
What did they do for the fine tune? Did that include all the new parts or were those to repair the current problem? It is not unheard of to get a bad part out of the box.
Dec 16, 2016 at 10:53 AM
LISA SIEGMAN
  • 21 POSTS
I had to replace my distributor cap and rotor and then I replaced timing chain and gears and my cam and crank was out of wack so I took it into the shop and they said I was out of tune so they hooked it to a scanner and had it timed right and ever since then I blew a coil pack and five plugs. I replaced the coil plugs and wires and now five will not quit fouling.
Dec 16, 2016 at 11:17 AM
HMAC300
  • 48,601 POSTS
if you have the resources put air into cylinder five and see if you can see air leaking into valve cover remove the valve cover if it is fouling like really quick it may be a broken ring. Or if you pull valve cover and a lot of oil comes out from that then clean your drain returns and clean out sludge then see if it continues.
Dec 16, 2016 at 11:37 PM
LISA SIEGMAN
  • 21 POSTS
That is something I will try. what is the best cleaner to use for the sludge? I have been doing this work with a little help.
Dec 16, 2016 at 11:50 PM
HMAC300
  • 48,601 POSTS
scrape out as much as you can then once drain holes are clean. I used to use a little mineral spirits, then change oil. that is if you have sludge and check PCV to see if it works.
Dec 17, 2016 at 2:40 AM
LISA SIEGMAN
  • 21 POSTS
Wierd question if u have a blown head will it constantly overheat or no or could I have a blown intake because I have heat don't overheat but I do have a blue tinted smoke coming from the exhaust and it looks like a fog machine
Dec 17, 2016 at 10:50 AM
STEVE W.
  • 15,413 POSTS
It's possible that an intake gasket has cracked and it's pulling oil in. Not real common for them to fail that way (these usually fail on the ends and leak coolant into the engine). Not that hard to pull the upper off and snake a camera in and check.
Dec 17, 2016 at 3:20 PM
HMAC300
  • 48,601 POSTS
if it looks like a fog machine then pressure check coolant system for a blown head gasket or intake gasket
Dec 18, 2016 at 12:01 AM
LISA SIEGMAN
  • 21 POSTS
If I do the intake then I might as well do the heads right just to be safe
Dec 18, 2016 at 12:17 AM
HMAC300
  • 48,601 POSTS
sure
Dec 18, 2016 at 1:23 AM
LISA SIEGMAN
  • 21 POSTS
What's the easiest way to do a head gasket on my 98 Chevrolet silverado 5.7
Dec 18, 2016 at 10:11 PM
HMAC300
  • 48,601 POSTS
rent a manual from us you can print instructions right from manual for what ever you need to do on your truck it's best done inside vehicle .
Dec 18, 2016 at 10:57 PM
LISA SIEGMAN
  • 21 POSTS
What is a ported vacuum switch for some reason I can not find it anywhere to buy
Dec 20, 2016 at 9:18 AM
STEVE W.
  • 15,413 POSTS
That looks like the vacuum port adapter for the power brake booster. Circled part yes?
Think it's a salvage yard or dealer only piece. Never really needed one. I'll look at the parts book and see if it shows up.
Dec 20, 2016 at 11:25 AM
STEVE W.
  • 15,413 POSTS
GM Part #12602245 from the parts book.
Dec 20, 2016 at 11:59 AM
LISA SIEGMAN
  • 21 POSTS
Thank you
Dec 20, 2016 at 7:20 PM
LISA SIEGMAN
  • 21 POSTS
What would cause a coolant oil mixture on the valve cover itself but it's not on my valves or in my oil not sure what's going on
Dec 20, 2016 at 8:40 PM
LISA M. SIEGMAN
What is that brown stuff
Dec 22, 2016 at 3:51 AM
STEVE W.
  • 15,413 POSTS
That looks like the goop you get when dexcool gets mixed with another coolant and gets air in it. Looks like new gaskets as well.
Oh the question earlier about the oil/water inside the valve cover. That can happen if it's humid or the vehicle doesn't get driven on a long drive to heat the oil and boil off any moisture.
Dec 22, 2016 at 6:26 AM
LISA SIEGMAN
  • 21 POSTS
Yes those are new gaskets i did that a few months ago but found out my lower intske was leaking so had to tale it apart again so i cleaned everything again and put new gaskets on it and also my lower intake was nlt torqued down lime it should have been im thinking thats been my whole problem im going to take it to get an acid flush done on it at a shop to clean the whole engine
Dec 22, 2016 at 7:36 AM
LISA SIEGMAN
  • 21 POSTS
Torqued like it should have been
Dec 22, 2016 at 9:00 AM
STEVE W.
  • 15,413 POSTS
Yep, a loose intake can cause a LOT of problems. On the newer engines like yours it's even worse because of the uneven clamping forces the bolt angle applies. That and the OEM plastic gasket are primary reason why a lot of folks don't like dexcool even when it wasn't the reason the gaskets failed.
Dec 22, 2016 at 9:49 AM
LISA SIEGMAN
  • 21 POSTS
So that would also cause a lot of condensation as well am I correct in normally do all the work but I've been busy and trusted a mechanic and he didn't even tourqe the bolts on the lower part and I kept getting a misfire on #5 and when I tore down my engine I seen all kinds of condensation and I was livid I put a lot of money into this truck and paid him good money and he almost screwed me out of a truck and this time it's completely tourqed the right way so hopefully no more problems and no more dex cool
Dec 22, 2016 at 10:20 AM
STEVE W.
  • 15,413 POSTS
Yep, water could easily get past a loose gasket. Oil could also get drawn in easily, in looking at your picture you can actually see the streaks in the intake runners on the head.
If you scraped all the crud down you will want to change the oil, use a cheap oil with one quart of ATF to help flush the crud to the pan, then change the oil & filter.
Dec 22, 2016 at 11:09 AM
LISA SIEGMAN
  • 21 POSTS
I will get that I sucked most of it out with a shop vac and wiped it down but when I do this with ATF DO I START IT TO FLOW THRU or do I just pour it in and drain
Dec 22, 2016 at 11:42 AM
STEVE W.
  • 15,413 POSTS
Start it and let the ATF run through the system, it will help dissolve the crud and flush it out. Then drain it while it's warm. ATF is basically a 10 weight oil with a lot of detergents and gum cutter additives. The older trick is to dump a couple quarts of kerosene in and run that until the engine is warm. It works but ATF is a lot safer for the engine parts.
Dec 22, 2016 at 8:59 PM
LISA SIEGMAN
  • 21 POSTS
Thank you I will do just that thank you so much for your help
Dec 22, 2016 at 11:16 PM
JOHNNY G.JR
  • 320 POSTS
Make sure you change filter also
Dec 23, 2016 at 2:29 AM
LISA SIEGMAN
  • 21 POSTS
Broken bolt on cylinder head WTF how can I remove it without replacing the whole thing don't have the money
Dec 24, 2016 at 10:36 AM
CJ MEDEVAC
  • 11,000 POSTS
Well,
The bolt diameter (not the head) is how big?
How much room is in front of the broken bolt?
Here's the tricky one!
Did the head bottom out (up top) and snap off?
OR
Did the bolts shaft go to the bottom of the hole and bottom out (then the head sheared off)?
Simpler terms, is there a space between the bolt tip and the bottom of the hole now that the head is broke off?
The Medic
Dec 24, 2016 at 10:57 AM
STEVE W.
  • 15,413 POSTS
Broken bolts are a PIA. Which bolt broke and how did it break, flush with the head, some part still sticking out, as removal is different?
My first step on a broken bolt is to take a center punch and mark the center of the broken part.
If part of it is sticking out I like to clean around it, then use a torch (propane is fine, butane even works) to heat the bolt. Now take a candle and place it against the bolt, the wax will melt and wick into the threads. Clean and heat it again. Then use a pair of vice grips to grab the stub and gently try turning it in both directions. Once you get it moving it will usually screw out.
If it broken off flush, it's a bit more work. Get a set (or just the sizes needed for the bolt you have) of LEFT hand drill bits and a couple broken bolt extractors to match.
Proceed as above except you don't use the vice grips. Instead you will pick a drill about 1/2 the size of the broken bolt. now drill in the center of the bolt and stop when you get to the point that an extractor will actually grab. Now place the extractor in the hole and tap it with a hammer STRAIGHT in, don't break the extractor. Now gently try unscrewing the bolt. If it doesn't come out with light force. Remove the extractor and heat it again. Repeat until it comes out.
IF you have a welder and the bolt is broken off with some sticking out, you can take a nut, place it over the broken bolt, weld it in place and they usually will come out.
Or you can just drill it out and install a heli-coil to get the threads back.
Dec 24, 2016 at 10:49 PM
LISA SIEGMAN
  • 21 POSTS
This is the pic
Dec 25, 2016 at 12:30 AM
STEVE W.
  • 15,413 POSTS
That should come out rather easily unless it was cross threaded going in. Left hand drill bit and be sure to drill straight down matching the angle of the hole to the right. Heat it up first, then some wax or lube. Then clean the flange around it and tape plastic around it so the chips get collected, a couple magnets under the plastic to hold the chips wouldn't be a bad idea. Then GENTLY drill it out. Wrap some tape around the bit to match the depth of the ones that came out. Try an easy out and see if it backs out.
A few videos on the topic
https://www.youtube.com/watch?v=c-VD1yx61bA
https://www.youtube.com/watch?v=3tjhs-0kFl8
https://www.youtube.com/watch?v=dbZZFWaIzyU
Best of luck.
Dec 25, 2016 at 7:51 AM
LISA SIEGMAN
  • 21 POSTS
Got the bolt out but come to find out have a cracked cylinder head on the drivers side
Dec 28, 2016 at 1:06 AM
