Engine misfiring and in limp mode
176,000 MILES • 5.4L • V8 • 4WD • AUTOMATIC
GIB FORREST
I was driving home one day and just started missing and went into limp mode cylinder 3 was the code. I have changed all the plugs and coils and it still misfires in cylinder 3 and 1 I have switched coils and plugs around and it doesn’t follow it it stays on 3 and 1.
Feb 22, 2021 at 10:04 AM
  • 110,248 POSTS
The next thing I would check would be compression and the fuel injector for cyl 3. It may be stuck or not operating. Also, low compression will cause a misfire as well.
Here are a couple of links to help. The first explains how to check an injector.
https://www.2carpros.com/articles/how-to-test-a-fuel-inje
When checking the injector, make sure it is getting a pulse (power) to fire.
Here is a link showing how to check engine compression:
_______________________________
Try these things and let me know the results. Also, let me know if you have other questions.
Take care and God Bless.
Apr 6, 2021 at 5:14 AM
