Login
Join
Ask a Question
Questions by Vehicle
Repair Topics
Testing / Diagnostics
Repair & Service Guides
Symptoms
Warning Lights
Trouble Codes
How It Works
Videos
Login
Become a Member
Home
Nissan
Maxima
Engine
Symptoms
Misfire
Cylinder one and two misfire
2000 NISSAN MAXIMA
200,000 MILES
DANIEL SABO
MEMBER
I have replaced the spark plugs, coil, and injector. I have done a compression test. They were good.
Aug 28, 2019 at 1:32 AM
Experienced Mechanic
Good morning.
What was the compression?
Did you check for any vacuum leaks?
Aug 28, 2019 at 2:15 AM
DANIEL SABO
MEMBER
Compression was wet 150. I did check for vacuum leaks.
Aug 28, 2019 at 3:47 AM
Do you have a noid light to be sure the PCM is commanding the injector to work?
Aug 28, 2019 at 5:03 AM
DANIEL SABO
MEMBER
it works.
Aug 28, 2019 at 7:23 AM
Okay, so it flashed when you cranked the engine. Correct?
Beyond that, you need to pull the valve cover and inspect for valve train damage.
Aug 28, 2019 at 7:31 AM
Add image or video
Ask a new question
Engine won't start
Engine stalls while driving
