Cylinder one and two misfire
200,000 MILES
DANIEL SABO
I have replaced the spark plugs, coil, and injector. I have done a compression test. They were good.
Aug 28, 2019 at 1:32 AM
Good morning.
What was the compression?
Did you check for any vacuum leaks?
Aug 28, 2019 at 2:15 AM
DANIEL SABO
Compression was wet 150. I did check for vacuum leaks.
Aug 28, 2019 at 3:47 AM
Do you have a noid light to be sure the PCM is commanding the injector to work?
Aug 28, 2019 at 5:03 AM
DANIEL SABO
it works.
Aug 28, 2019 at 7:23 AM
Okay, so it flashed when you cranked the engine. Correct?
Beyond that, you need to pull the valve cover and inspect for valve train damage.
Aug 28, 2019 at 7:31 AM
