Hi I'm needing help I'm having problems with misfire that causes my check engine light to flash and then my car dies.
I have done the following to it to try to fix the problem:
1.valve cover gaskets
2.spark plugs
3. Coil packs
4.fuel injectors
5.thermostat
6.mass air flow
And fixing to change knock sensor 2 will that solve the problem.
2.spark plugs
3. Coil packs
4.fuel injectors
5.thermostat
6.mass air flow
Jun 14, 2019 at 12:11 AM
