Running rough and misfire code
240,000 MILES • 5.3L • V8 • 4WD • AUTOMATIC
BFELCH129
I bought the truck three years ago. I replaced the alternator and battery two years ago. water pump and coolant flush last spring. Now it is running rough and I have a misfire code. So far I have replaced the plugs wires.
Dec 21, 2018 at 5:51 AM
Good afternoon,
What is the exact code?
Have you checked the compression?
Dec 21, 2018 at 6:22 AM
BFELCH129
Hello Roy,
I am using The snap-on ETHOS scan tool and it displayed P0300. When i checked misfire data it showed Bank 1 cylinder 1, 3, 5 and 7 all with misfires. the passenger side plugs were white, the driver side were black carbon fouled. I'm a little confused as i thought Chevrolet V-8 engines cylinder number one is passenger side front cylinder.
Dec 22, 2018 at 1:07 AM
Number one on all GM engines is drivers side.
Do or did you check the fuel pressure?
Did you replace the plugs?
Dec 22, 2018 at 1:13 AM
BFELCH129
Yes, I have replaced the plugs and wires.
The fuel pressure is:
Ignition on engine off is like 32psi.
Ignition on engine running is 60psi.
Dec 26, 2018 at 7:01 AM
Okay,
What is the compression?
The next step is injectors. need to be sure they are working and being commanded on.
https://www.2carpros.com/articles/how-to-test-a-fuel-injector
I would have them professionally cleaned. the additives have no effect on cleaning at all.
P0300
Descriptor
Probable Causes
Crankcase Ventilation System for Vacuum Leaks
Exhaust System Has Restrictions
Fuel Injector
Fuel for Contamination
Ignition Coil
Powertrain Control Module (PCM) Grounds Corrosion
Spark Plug
Throttle Body and Intake Manifold Vacuum Leaks
Vacuum Hoses and Seals Improper Connections
Vacuum Hoses and Seals Restrictions
Vacuum Hoses and Seals Splits
Dec 26, 2018 at 7:06 AM
