Misfiring at 2,500 RPM's, worse when driving up a hill
150,000 MILES • 2.7L • 4 CYL • 4WD • AUTOMATIC
GDUNN9
  • 5 POSTS
My truck is misfiring when ever I am at around 2,500 RPM's, once I give it more gas the misfire will go away. it also misfires worse when I’m going up a hill. I will be more than happy to give more information. Thanks for any help.
Dec 4, 2020 at 12:30 AM
DANNY L
  • 5,648 POSTS
Hello, I'm Danny.
Is the check engine light on? If so that means a diagnostic code is stored in the cars computer. Here is a tutorial showing what is involved for checking codes:
If you don't have access to a code reader or scanner most auto parts stores have a tool loaner program and can rent you one. Auto parts store like AutoZone can check codes for free. I also believe you could possibly have problems with a plugged or failing catalytic converter. Here are a few tutorials on catalytic converter symptoms and replacement for you to view:
https://www.2carpros.com/articles/bad-catalytic-converter-symptoms
Get back to us with any code information or tests you performed and we'll go from there to help with diagnosis. Hope this helps and thanks for using 2CarPros.
Dec 4, 2020 at 10:18 AM
GDUNN9
  • 5 POSTS
Yes, the check engine light was on about a month ago. I checked it to see what codes they where and they where misfire on cylinder 1, 2, 3, 4 and also a random misfire code. After that I changed all the spark plugs and it doesn’t show those codes anymore but it does the exact same thing.
Dec 4, 2020 at 11:54 PM
GDUNN9
  • 5 POSTS
Also if it helps any this truck had been sitting for about 2 years before I started messing with it.
Dec 4, 2020 at 11:57 PM
DANNY L
  • 5,648 POSTS
Hello again.
Okay, since you mentioned that you changed the spark plugs and that has taken care of the misfire then I would suspect you might have a plugged or defective catalytic converter as I stated in the last post. If you have access to an infrared gun the best way to test for blockage or deficiency is to measure the heat at the inlet and outlet. The outlet temperature will always be hotter than the inlet in a properly working catalytic converter due to the catalyst process. If the converter is bad due to blockage or failure then the outlet temperature will be lower than the inlet. If you don't have access to an infrared heat gun most auto parts stores have a tool loaner program and can rent you one. You can also buy relatively cheap at a hardware store or home improvement stores. Let us know what you find out and we'll go from there after testing. I've attached pictures below of its location and removal for you. Hope this helps and thanks again for using 2CarPros.
Danny-
Dec 5, 2020 at 9:10 AM
GDUNN9
  • 5 POSTS
Sorry it took so long for me to get the catalytic converter checked, but I check it today and it was 200 degrees hotter at the outlet than it was at the inlet. I think I forgot to tell you this but it also run a lot worse when it is cold like it will barely go until the engine gets warmed up.
Dec 14, 2020 at 1:55 AM
Thanks for the additional info. This would actually support what Danny is suggesting that you could have a plugged exhaust. What appears to be happening is when the RPM is raised, it is not able to move enough air through the exhaust due to the restriction. Then the restriction is causing a misfire and the raw fuel is going through into the converter where it is burning in the converter causing the higher outlet temp. I would suggest removing the up and down stream o2 sensors and drive the vehicle. It is going to be loud but should not misfire any more. If it does not at 2,500 RPM's then you need to replace the converters.
https://www.2carpros.com/articles/exhaust-system-removal
Also, here is the process below of the converter from the manual. Let us know what you find. Thanks
Dec 17, 2020 at 4:54 AM
DANNY L
  • 5,648 POSTS
Hello again.
Just checking in to see if you were able to test and see if you have excessive back pressure in the exhaust system-muffler from our last post causing this drivability issue. Thanks again for using 2CarPros and keep us updated or let us know if you have any further questions. Happy Holidays.
Danny-
Dec 20, 2020 at 4:16 PM
GDUNN9
  • 5 POSTS
I finally got so time to work on it and I tried to get the o2 senors out but I couldn’t so I just went ahead and cut the bolts off the catalytic converter so I could get it off and it did not change anything when I took it off it still misfired just as bad. Any other suggestions would be greatly appreciated. Thank you
Dec 21, 2020 at 11:57 PM
Have you monitored fuel trims to confirm this is rich? I don't think it is necessary as it is a safe assumption but I don't like to make assumptions because if we are wrong every thing from that point is wrong.
However, if we have a rich exhaust then that means the issue you are having is a misfire that is not burning all the fuel. So that raw fuel is going into the exhaust and it is burning in the converter which is why the temp is higher coming out.
So if it is not clogged then we have to go back to the engine and cover the basics. Pull the plugs and get a picture of them so we can see if they are fouled. If they are they need to be replaced. I attached below a chart showing spark plugs that are worn. That will give us more info as to what the issue is.
Then we may need to replace or at least try and clean the injectors because they may be sticking and dumping too much fuel.
Let us know what the plugs look like and we can go from there. Thanks
Dec 23, 2020 at 10:07 AM
DANNY L
  • 5,648 POSTS
Hello again.
I'm leading to believe the injectors might be sticking allowing more gas than usual to enter the cylinders and causing a rich condition resulting in misfires. This might be caused also as you stated by the truck sitting for 2 years and having them being gummed up from sitting with old gas. There is a Seafoam brand treatment you might want to try using to help free up the injectors. You just add to the gas tank. I was able to start a car after sitting 5 years with old gas in the tank and wouldn't start by using this. I've attached a picture below of what Seafoam brand looks like. It is available at auto parts stores. Hope this helps and thanks again for using 2CarPros.
Danny-
Dec 23, 2020 at 10:47 AM
