Misfire
BIG FERN
  • 2001 FORD WINDSTAR
  • 218,070 MILES
It's making a burn mark in the middle of my number 2 spark plug
Sunday, April 28th, 2013 AT 2:56 PM
HMAC300
  • 48,601 POSTS
Check to seeif it's kind of grayish it may be the plug wire is leaking causing that.
Sunday, April 28th, 2013 AT 3:14 PM
HMAC300
  • 48,601 POSTS
Also check the fuel pressure low fp will cause misfires
CARADIODOC
  • 33,873 POSTS
I assume you mean along the outside of the spark plug. Replace the spark plug and the wire. Once arcing takes place it leaves a carbon track behind inside the boot. That is a conductor and it will continue to arc there until both parts are replaced.
Sunday, April 28th, 2013 AT 3:18 PM
