Please let us know what you find so it will help others.
Best, Ken
Oct 4, 2016 at 3:45 AM
SUHAYL
MEMBER
Hi there thanks for the help but nothing wrong with the valves or springs is it a possibility the rockers or lifters could cause that?
Oct 4, 2016 at 4:02 PM
✓Experienced Mechanic
Yes, with the ignition dissembled crank the engine over to see if each rocker moves up and down. If not you may have a flat camshaft.
Best, Ken
Oct 5, 2016 at 2:55 AM
SUHAYL
MEMBER
Check everything new cam different rockers and different lifters problem presists any other ideas?
Oct 5, 2016 at 3:51 AM
Does the car have any trouble codes can you scan it it see what it shows?
Oct 5, 2016 at 2:12 PM
SUHAYL
MEMBER
That's the funny thing scan the car no fault code pertaining the misfire.....
Prior to the vehicle cutting out the engine light came on when the vehicle speed was above 100km/h and when you slow down pass 100km/h she goes back off
Oct 5, 2016 at 10:10 PM
It now sounds like it could be the timing chain has jumped. Does the engine sounds normal when cranking over. Can you perform the compression check?
Oct 6, 2016 at 2:30 PM
