Misfire in cylinders two and three
160,000 MILES • 2.4L • 4 CYL
RKIWI1966
Put new starter in and a month later it starts mis firing in cylinders 2 and 3. Changed injectors, plugs, caps, crankshaft sensor, MAP sensor, cleaned MAF sensor. Watched a video on putting an OEM starter in there because the one I put in was a cheap starter. Erase codes and they come back as mis fires in 2 and 3. When problems first started code reader said only crankshaft sensor. After replacing sensor, the codes show for misfire in cylinders 2 and 3. Start it up and it idles great and revs up to 5,000 RPMs with no misfire, then after about 10 seconds engine light comes on and it misfires when accelerating but not while idling.
Mar 11, 2022 at 8:03 AM
  • 110,248 POSTS
Have you checked to make sure there isn't a head gasket issue between the two adjacent cylinders? If you haven't, start by checking engine compression to see if they are a lot lower. Also, are P0302 and P0303 the only codes you are getting? Let me know if there are more.
As far as the compression test, here is a link that explains how it's done:
Additionally, here is a link that explains what to look for when checking a possible head gasket issue:
Just a few more questions. Let me know if you notice any dark smoke from the exhaust or if there are any odd smells from the vehicle.
Take care and I'll watch for your reply.
Mar 11, 2022 at 11:50 AM
JIS001
  • 3,412 POSTS
Looking at your mileage the first thing I would recommend doing is checking your valve clearance. The exhaust valves tend to get tighter with high mileage.
Mar 12, 2022 at 3:52 PM
