how to switch the temperature display in the Mini Message Center from Fahrenheit to Celsius
68,000 MILES • 5.4L • V8 • 4WD • AUTOMATIC
CHE BURROWS
  • 6 POSTS
G'day guys.
My truck is equipped with a Mini Message Center.
Can you please tell me how to switch the temperature display in the Mini Message Center from Fahrenheit to Celsius?
VIN# 1FTPW14565FA67327
Mar 5, 2018 at 10:18 AM
  • 31,937 POSTS
If you have the three buttons at the bottom of the message center it can do a re-configured using these. check your owners manual, if not and it is a base model you will probably have to get a dealer to do it with the IDS as this will access central configuration and they should be able to do it this way.
Mar 5, 2018 at 5:55 PM
CHE BURROWS
  • 6 POSTS
Thanks for the word, much appreciated.
Yes, basic Mini Message Centre in my truck.
I am in Australia, so I need to find somebody with the IDS tool suitable for a USA made vehicle.
Mar 5, 2018 at 6:13 PM
  • 31,937 POSTS
You Ford dealer will use an ids that is compatible. I work at a rural Ford dealer in Victoria and I am sure that the standard ids should do the job give them a ring just to make sure that they can do it.
Mar 5, 2018 at 6:18 PM
CHE BURROWS
  • 6 POSTS
Thank you mate.
How do I contact you?
Mar 5, 2018 at 9:39 PM
  • 31,937 POSTS
Where do you live? I do not give out personal contact details. I may be able to direct you to a suitable work shop.
Mar 6, 2018 at 4:03 AM
CHE BURROWS
  • 6 POSTS
Victor Harbor in South Australia.
Mar 6, 2018 at 4:38 AM
  • 31,937 POSTS
Looks as if you will have to head off to Adelaide to get this done. i doubt that a general scanner will do this option, best ring a few dealers first and make sure that you do not waste a trip first.
Mar 6, 2018 at 4:38 PM
CHE BURROWS
  • 6 POSTS
Thanks again.
I have been working on finding someone with the right IDS tool and willing to have a crack at it.
Do you know if the application Forscan can get access to instrument cluster programming?
Mar 6, 2018 at 4:41 PM
  • 31,937 POSTS
i am not sure, i have not used it before. if you have someone with it nearby it may be worth asking them if they are happy to give it a try, if it links up it will be a simple fix.
Mar 6, 2018 at 5:42 PM
CHE BURROWS
  • 6 POSTS
Thanks mate.
I do not know how we would all be driving cars these days without computers.
Mar 6, 2018 at 5:54 PM
