Will not start
2009 MINI COOPER S
99,000 MILES • 1.6L • 4 CYL • 2WD • MANUAL
YOUNG888
The car will turn over and almost start, but will not fire up.
The ECU has been tested and is fine.
All the fuses have been checked and are okay.
The high pressure fuel pump has been replaced.
The fuel pressure regulator has been replaced.
The fuel pressure sensor in the rail has been replaced.
There is fuel and spark.
There is a fault saying " high pressure injection valve triggering" on all four cylinders.
Any ideas?
Nov 13, 2018 at 7:48 PM
MOTOR MASTER
  • 279 POSTS
Hello my name is Dave.
It sounds like there is a good chance the injectors are not getting a signal, if you could give me the trouble code number I will be happy to help you track down the issue.
Nov 15, 2018 at 12:55 AM
