2005 Mini Cooper S Warning Lights
2005 MINI COOPER S
80,000 MILES • 4 CYL • 2WD • MANUAL
PETERCURIALLE
I recently had a flat tire and the warning light went on (horseshoe shaped) as well as another light (a triangle with an arrow around it) . I had the run flat tire replaced and the pressure is fine in all tires but both lights remained on. What causes this?
Oct 11, 2010 at 12:00 AM
EAGAN11
  • 15 POSTS
the a triangle with an arrow around it is the DSC light. When you have a flat tire the DSC system see's it. the TPM system and the DSC system are tied together, so to speak. The DSC will not be active durining this condition.
Oct 14, 2010 at 9:02 AM
