2005 Mini Cooper S run flat tures
2005 MINI COOPER S
32,000 MILES • 4 CYL • 2WD • AUTOMATIC
SUZY711
I have run flat tires on my car and I just got them in May, yesterday the tire pressure signal came on indicating that I may have a flat or significantly low air pressure. I was wondering how I can tell? Also am I supossed to put air in these tires just like normal tires?
Jan 21, 2009 at 3:56 PM
JACKR
  • 5 POSTS
Yes, they need air just like a normal tire. A regular tire pressure gauge is all you need. Any tire shop / service center should be able to check your air pressure for you. Your owners manual will tell you what the pressure should be, or you may have a sticker inside the door opening.
Apr 15, 2009 at 10:28 AM
