2005 Mini Cooper S Hot battery cable
49,700 MILES • 4 CYL • FWD • MANUAL
RR330I
The positive terminal cover on my 05 MCS seems to have melted off of the terminal. I covered w/ electrical tape, and it melted! The terminal and the cable were hot to the touch.
I was able to zip tie the cover back on.
What can cause this?
I am being told i need to replace the battery cable assembly which runs from the 'trunk' to under the hood.
Sep 27, 2010 at 6:08 AM
EAGAN11
  • 15 POSTS
CHeck the 13mm nut on the pos battery cable, those have been known to be loose and cause them to be hot.
Oct 14, 2010 at 9:04 AM
