2005 Mini Cooper S hard starting when cold
HABIGER
Engine Performance problem
2005 Mini Cooper S 4 cyl Front Wheel Drive Manual
I need to crank engine for 30-60 seconds to start after setting over night. starts and runs perfect during day. It appears to not get enough fuel when cold.
Also, would this be covered under 4 year warrenty?
Jul 28, 2009 at 1:51 AM
DOCFIXIT
  • 18,828 POSTS
Hi
Is check engine light on? Maybe a faulty coolant temp sensor located rear of engine below air snorkle.
If sensor out of range it can cause cold start problems. Not sure of Mini warrenty but I would give them a call.
Hope this helps
Thanks for donate
Jul 28, 2009 at 3:13 AM
