2003 Mini Cooper S Driver's side door lock
66,000 MILES • 4 CYL • FWD • MANUAL
BLUTOASKI
  • 7 POSTS
The automatic door lock on the driver's side door has stopped locking. It doesn't lock or unlock with the Key Bob or the door lock switch on the console. The passenger side and rear hatch both work with the bob and console switch. I have checked all the fuses. What could be the cause of this?
Mar 19, 2010 at 9:43 AM
KHLOW2008
  • 41,812 POSTS
Hi blutoaski,
Thank you for the donation.
Symptoms indicates a fault with the door lock actuator, ( motor for locking and unlocking ).
You would need to test the actuator motor operations.
Mar 20, 2010 at 7:41 PM
