2006 Mini Cooper Flat tire
15,000 MILES • 4 CYL • 2WD • AUTOMATIC
LSLATER999
Hit a curb last nite coming into driveway, front passenger tire flat. don't know if cut tire or poped it off and lost the seal. Right side parl=king lights are on and won't go off. Is this a tire problem warning light?
Oct 18, 2009 at 6:18 AM
MATHIASO
  • 1,209 POSTS
the parking brake piston may need to be resett or there is damage to it after you hit the curve on that side. Check the whole system to see what the problem is Use an 8mm Allen to remove the caliper pins use this tool to retract/ resett the piston, can be found at autozone
https://images.2carpros.com/forum/automotive_pictures/46384_this_2.jpg
Oct 18, 2009 at 8:56 AM
