2003 Mini Cooper Air Conditioning Clutch problem
2003 MINI COOPER
37,000 MILES • 4 CYL • FWD • AUTOMATIC
KEDENS
I also am having AC trouble -no system leaks - freon level is fine, fan works, but no cool air. The clutch is not kicking in - perhaps an electrical problem. My understanding is replace the clutch assembly requires a new compressor ( $$$$ ). Any suggestions would be appreciated. Thanks
Apr 28, 2008 at 4:23 AM
  • 31,937 POSTS
Hi there,
The first thing to do with any A/C issue is to get the hi/low pressures checked, this will tell the tech a great deal about the condition of the A/C it well may be a pressure issue and the high/low pressure switch has activated shutting down the system.
mark (mhpautos)
Apr 28, 2008 at 10:08 PM
