My wipers just stopped working and all the fuses are good so what could the problem be?
Jun 2, 2009 at 3:59 AM
DAVE H
✓Experienced Mechanic
check the motor .. check the switch
Feb 22, 2010 at 9:54 AM
YAAHSHOE
MEMBER
I had the same problem did everything you can think of , so after awhile I figured to try something simple I run a ground strap from motor mounting bolt to a good ground spot, and haven't had a problem after that, this also worked for others on diffrent web sights .
Jun 9, 2010 at 12:43 PM
MRNESQ
MEMBER
It's the motor. You need to replace it. Happened to me at 90,000 miles.
