Check the lower intake gasket for possible coolant leaking into oil. If okay, and have overheated recently then the cylinder heads need to be removed to inspect for cracks and to see if the head is warped.
Dec 10, 2017 at 7:19 AM
TRACY VOGLER
MEMBER
Car is not over heating though.
Dec 10, 2017 at 7:35 AM
JIS001
✓Experienced Mechanic
Then check the lower intake gasket for a leak. If gasket is bad it can cause coolant to leak into the oil.
