Milky oil
99,000 MILES • 5.0L • V8 • RWD • MANUAL
RACHEL LEE SCHOENROCK
I have rebuilt headers and replaced gaskets. cycled oil through three times still milky. My coolant is low always burping it help keep the car cool. nothing helps
Sep 23, 2017 at 10:55 AM
JOHNNYT73
  • 924 POSTS
You definitely have coolant getting into the oil. If the coolant keeps having bubbles come up and never fully burping then those will be combustion bubble getting into the cooling system. You can take out spark plugs to inspect them and the chamber with a scope if you have one to see which cylinder is the culprit.
Sep 23, 2017 at 2:06 PM
Okay, thanks so much I will try this.
Sep 23, 2017 at 2:14 PM
  • 55,766 POSTS
Here is a guide that can help as well.
https://www.2carpros.com/articles/coolantantifreeze-in-the-engine-oil
Please let us know what happens and upload pictures or videos of the problem.
Cheers, Ken
Sep 26, 2017 at 4:37 AM
Thank you ill check it out and hopefully get some this weekend posted.
Sep 27, 2017 at 2:51 PM
  • 55,766 POSTS
Sounds good
Sep 28, 2017 at 4:47 AM
