Replaced instrument cluster with new/used with incorrect mileage, can it be corrected
57,106 MILES • 1.6L • 2WD • MANUAL
VULCANO3179
  • 10 POSTS
I recently replaced my instrument cluster on my car listed above GL
model. Before i did this the mileage was 57,106, now that i have a different cluster it reads 63,347. Is it at all possible for a mechanic to correct the mileage?
Many thanks.
Aug 15, 2019 at 9:48 PM
STEVE W.
  • 15,370 POSTS
Welcome back. Yes it is possible for it to be corrected but you would need a dealer to do it as it requires a security code to adjust the mileage.
Aug 16, 2019 at 10:36 AM
VULCANO3179
  • 10 POSTS
Okay, so would it pass an mot with the wrong mileage? As my nearest VW dealer is 15 miles away.
Aug 16, 2019 at 3:50 PM
STEVE W.
  • 15,370 POSTS
Being in the US I'm not sure if it would be an issue. I know here it wouldn't be simply because the "new" number is higher than the old one. However if you go to
https://www.gov.uk/government/publications/mot-inspection-manual-for-class-3-4-5-and-7-vehicles
https://www.gov.uk/government/publications/mot-inspection-checklist-vt-29
You can download the test sheet and the instructions as to what has to be checked to get an MOT completed in the UK if that is where you are located.
Aug 16, 2019 at 4:21 PM
VULCANO3179
  • 10 POSTS
Hi, yes i am in the UK. i will take your advice and do some research. thank you for your help and time, many thanks.
Aug 16, 2019 at 8:39 PM
STEVE W.
  • 15,370 POSTS
That is the gov. site for the MOT. It will not let anyone outside the UK download it because of the "security rules" they have in place. I asked a friend who does MOTs but have not heard back.
Aug 16, 2019 at 11:40 PM
