Mg5 4x4 transmission length?
86,000 MILES • 4.3L • V6 • 4WD • MANUAL
B.LUV
I have the truck listed above. I need to figure out if this other transmission that I bought is actually for a 4wd like I was told by the seller. The only visual difference that I know of would be that the 4x4 version would be shorter in length.
What is the length of a 2006 Silverado mg5- 5 speed manual 4x4 transmission?
Also, what is the mg5 manual 2wd length?
Oct 30, 2022 at 2:37 AM
  • 55,770 POSTS
I don't have demissions for you sorry, but the difference between a 4x4 and 2x4 is easy because the tail shaft is way different, here are images of both so you can see the difference. Check out the images (below). Please let us know if you need anything else to get the problem fixed. The 4x4 transmission will not have the tail shaft housing.
Oct 31, 2022 at 2:57 AM
