2004 MG ZR central locking
33,400 MILES • 4 CYL • 2WD • MANUAL
VINCE NELSON
my central locking is making a grinding noise when the doors are locked with the remote the boot lock was not working too so i replaced the catch and the plastic locking unit which worked when the boot was open but on closing the boot the n locking with the remote the boot will not lock i then orened the boot pressing the fob the locking mech on the unit retratced so i placed a screw driverl locking the latch and pressed the remote the unit failed to work any help as i dont want to replace parts if i dont need to thanks vince
Feb 10, 2010 at 7:20 PM
DAVE H
  • 13,383 POSTS
check the wiring connector is on correctly and the lock actuator is aligned correctly
Mar 16, 2010 at 12:43 AM
