2004 MG ZR
MATTHEW210491
Engine Cooling problem
2004 MG ZR 4 cyl Front Wheel Drive Manual 60.00 miles
hi after a bit of advice please my car is over heating and the heaters are cold i have change the rad,thermostat,waterpump,timingbelt and now i have even changed the engine because i got told the liner had gone in the bottom end but it still over heats would u now wat the problem is please thanks
Mar 5, 2010 at 6:58 PM
DAVE H
  • 13,383 POSTS
is the vehicle over heating or is it a bad coolant temp sensor .. check engine compression to check for headgasket failure
Mar 16, 2010 at 12:46 AM
