2003 MG ZR Question to hopefully rule out head gasket
MDSWAIN
Engine Cooling problem
2003 MG ZR 4 cyl Front Wheel Drive Manual 67K miles
Hi
I Have a problem with my MG ZR.
I susupect head gasket, but i am not 100% sure.
i have milky residue inside the water tank, non under the oil cap.
there is no obvious sign of leakage from either the rad or any of the piping, and the temperature gauge shows normal 1.e halfway between hot and cold.
please can you give me some advice or possible causes
Aug 16, 2009 at 10:51 PM
DAVE H
  • 13,383 POSTS
milky residue is a definate sign of headgasket failure .. have a cylinder compression test carried out to be sure !!
Aug 30, 2009 at 10:13 PM
