2001 MG ZR
2001 MG ZR
44,000 MILES • 4 CYL • FWD • MANUAL
VALLIEGONZO
my mg zr 1.4 wont start. I got a diagnostic test done and this is what it says it showed a few problems. I only what it to start please help. (1)* fuel pump relay circuit high (fuel pump relay short to battery)* (2)* MIL-circuit fault* (3)* cooling fan 2 control circuit malfunction* (4)* evaporative emission control system purge control valve circuit shorted* (5)* engine oil temperature sensor low* (6)*fuel level sensor circuit low input* (7)* misfire detected sufficient to cause catalyst damage* (8)* misfire causing excess emission* (9)* fuel trim malfunction (bank 1)*. Thanks a lot guys
Mar 7, 2010 at 7:49 PM
DAVE H
  • 13,384 POSTS
check the inertia fuel cut off switch has not been tripped !
Mar 16, 2010 at 12:48 AM
