2004 Other MG Models losing coolant
MULLEY
  • 2004 MG
  • 6 CYL
  • FWD
  • MANUAL
  • 72,000 MILES
My mg zs is losing coolant, seem to be filling it up once a week, had the head gasket checked, no fault there. Coolant tank also has some gunge in, no leaks visable on the ground.
Tuesday, July 28th, 2009 AT 3:21 PM
  • 31,937 POSTS
Hi there,
The first thing you will have to do is get the cooling system pressure tested, then a tests for exhaust gasses in the cooling system, start here.
Mark (mhpautos)
Tuesday, July 28th, 2009 AT 4:44 PM
MULLEY
Thanks mate, appreciate that, I thought it was gunna be a problem with the radiator, so I was gunna put some radweld in it, but your suggestion makes more sense, thanks, paul.
Wednesday, July 29th, 2009 AT 12:29 PM
  • 31,937 POSTS
Hi there,
you don't want to be adding stop leaks to cooling systems as they can cause more harm than good, see how you get on with the test and post back if you have more questions, thats what we are here for.
Mark (mhpautos)
Wednesday, July 29th, 2009 AT 5:44 PM
