1961 Other MG Models Head gasket
JOHN BATES
  • 1961 MG
  • 6 CYL
  • MANUAL
  • 200,000 MILES
My car is actually a Morris Major, built in 1931, but this category was unavailable.
The engine has been completely rebuilt but after less than 50 miles, has blown the head gasket twice. The engine runs hot and feels 'tight' on the handle, but the elec. Starter has no problems coping with it. The engine starts readily and sounds good.
I believe the problem is overheating, but how/why is there coolant in all six cylinders? Why is the gasket blowing? First time it blew between cylinders 5 and 6. The second time is unknown as the head has not been removed yet.
John Bates
Redditch, UK
updated 10/26/09
Well, thanks for the reply.
When the engine was rebuilt at a reputable engineering shop, both head and block were skimmed and pressure tested and found to be fine. The engine was rebored, and new pistons and rings fitted, etc.
Now the head has been taken off again it can be seen that the gasket has blown between cylinders 5 and 6 just as before, and there was water in each cylinder. A new, hand made gasket has been fitted and the engine still runs hot. I suspect the water pump, which is driven off the back of the dynamo (generator), and have removed it for inspection. At the moment it is resisting all attempts to open it up!
Thanks again.
updated 10-27-09
I now think I have solved my blown head gasket problem which was always accompanied by water in all cylinders and water in the sump, mixed with the oil.
The engine is overheating and having removed the water pump I think I have the culprit. With the pump full of water, I had it spinning using an electric drill (forward and reverse) and NOTHING happened. It is not pumping. All I have to do (ALL?) Is open it up and see if it can be repaired. I'm not going to be able to buy a new pump for a car made in 1931!
Wednesday, September 30th, 2009 AT 4:09 AM
HMAC300
  • 48,601 POSTS
If the engine was rebuilt was it done at home or by a reputable shop? If it keeps blowing then there are a few things to check. ONe would be to check the head/deck flatness. If it is over.003" then it will need to be remachined or milled. The.003" would be on each piece. If the head or deck is out of spec then the corresponding piece needs to be remachined. Or the head torque may be to low. If it ihas studs with nuts for head bolts then it should be torqued to about 50# if fine thread.
Saturday, October 24th, 2009 AT 1:47 PM
HMAC300
  • 48,601 POSTS
This will be difficult for me to diagnose as I don't have the car here. But the reason you are getting water in all the pistons is due to water entering one while the engine is running then being sucked into the intake valve when it opens and goes from there. If you suspect the water pump I would check for the impeller or where it mounts to be loose and not spinning under load. As you have now stated that this is a homemade head gasket are all the holes on the block as well as the cylinder head open. Two other things that come to mind is a bad or improperly installed thermostate and a clogged radiator. After the engine gets warm shut it off and put your hand against the radiator all over. If you feel cold spots that is a good indication that the radiator is not working correctly as those may be blocked. These are the only things I can think of at the moment.
Monday, October 26th, 2009 AT 2:40 PM
