1975 MG Midget Radiator
1975 MG MIDGET
OJAIT
Engine Cooling problem
1975 MG Midget 4 cyl Two Wheel Drive Manual
My MG needs coolant every couple days! The car runs fine its charging fine water pump is new .The only thing I can think of that could be causing this is the differant preasure caps on my overflow and radiator because the overflow tank does not run dry. There apeers to be no leaks anywhere! any thoughts?
May 31, 2010 at 6:44 AM
  • 31,937 POSTS
Hi there,
have the cooling system pressure tested to make sure of no external leaks, they can also test the pressure cap, start here.
mark (mhpautos)
May 31, 2010 at 11:03 AM
