DO YOU SET THE TIMING AT THE CRANK PULLY OR AT THE FLYWHEEL AND WHAT IS THE PROPER SETTING
Feb 19, 2009 at 4:25 PM
DAVE H
✓Experienced Mechanic
We do not have the tech spec's for this vehicle i'm afraid .. your local library or autoparts store should be able to supply a repair manual for the vehicle with all the details you need and diagrams !
