1974 MG Midget failure to re-start
CCHASE33
Engine Performance problem
1974 MG Midget Two Wheel Drive Manual ? miles
The car starts and runs fine, but after shutting off it will not start again for 20-30 minutes. It cranks fine - plenty of battery juice - but will not fire until it has "rested"! I can't tell if it is an electrical problem or a gas problem - there seems to be plenty of both.
May 23, 2009 at 8:10 AM
  • 31,937 POSTS
Hi there,
Thank you for the donation.
Check spark when it won't run by first checking for voltage at the Pos side of the coil, if this is ok, remove the distributor cap and turn the engine by hand ignition off till the points open, check the gap about .012" should be ok, i will need to find the exact specs if you need them. place the test light on the neg side of the coil and turn the engine by hand, check that the light goes on and off as the points open & close, on No 1 check that the timing is around 5 Deg BTDC when the light goes on this is static timing, if the coil is very old replace it as it may be breaking down when hot, this can be tested on an oscilloscope, as for the fuel system, make sure that the carby has adequate fuel supply, check these basics first.
Mark (mhpautos)
May 23, 2009 at 2:03 PM
